Speedometer Correction is it Possible
gadawg31
GA
1979 CJ-5
258cu in 6cyl
T-150 3 speed Transmission
Dana 20 Transfer case
Dana 30 Front axle (almost 100%)
Fiberglass Tub
I have been seeing the Jeep speedometer gears from Morris 4x4 and it looks pretty simple. Has anyone done this? If so, what type of project scale would you give it? I just put the tub back on my jeep, so I would have to come from underneath the jeep. I would like to get as close as possible to actual speed reading, but a +or- 3 to 5 mph would be just fine. Any thoughts. Thanks.
JD
Thanks PaRenegade! I have been searching all over the web and have found all sorts of ratio adapters and gears, but I just have not seen a lot of them refer to the jeeps. This was mainly why I asked the question. From some of the research, it made it sound like I needed a special adapter built. The jury is still out of this one. I need to wait until I get home, since I can't see all of your pics here at work. These gov't computers won't load certain pics. I will review the post again, when I get home and go from there. Thanks for the input.
JD
If indeed your Jeep is a 1979 and if indeed you still have the Dana 20 Transfer Case , the above information does not apply to your Jeep. That is for a Dana 300 Transfer Case , not a Dana 20 Transfer Case .
The gears are not interchangeable between the two units.
You will have to search for the proper driven gear to match to your Dana 20 drive gear.
In my opinion, one tooth is worth about 6-8 MPH with this type of gear set-up.
Yes, my oversight. The info I posted applies to the Dana 300 Transfer Case . I'm not familiar with the Dana 20 's speedo. Sorry
They may be able to still help in some way if you call them.
"Call Kerry at 1-888-8771008 with your needs."
Yep, you'll have to get an adapter if you have a Dana 20 . That said, the same website listed above
Speedometer Gear, Speedometer Gears, Ford, GM, Dodge 700R4
has a ratio adapter. They aren't cheap, but it should work. I've got to get one for my 83 GMC truck.
As for the long shaft gears that are used in the 80-86 Dana 300 's, they're cheap on ebay. Just search for "mopar speedometer gear" or "dodge speedometer gear"
