spring sag
spring sag
Jimmy Jeep
Oregon
1964 CJ5
I have 64 CJ5 that lists to the left. It hasn't always been like this. I decided to rebuild from the ground up. It has original springs and aftermarket shackles. I run a small tire and am not looking at lifting it but need to replace the shackles for sure. The front is supporting a Ford v-8. Any suggestions on a 1" lift or replacing the shackles/springs?
I have 64 CJ 5 that lists to the left. It hasn't always been like this. I decided to rebuild from the ground up. It has original springs and aftermarket shackles. I run a small tire and am not looking at lifting it but need to replace the shackles for sure. The front is supporting a Ford v-8. Any suggestions on a 1" lift or replacing the shackles/springs?
I don't know of any one making any thing smaller than a 2" spring lift.
If you are mechanically inclined, you can add a leaf to your springs, but since you already have a uneven sag issue. I would advise having them re-arched & having a leaf added at the same time. A 2" lift isn't really to high IMHO.
I like "M.O.R.E." shackles. Lubeable Jeep Shackles/Greasable Shackles for Jeep YJ & CJ Models
