SSBC Disk Brakes install on a AMC 20 Full Floating Axle
JamesBryan
Layton, Utah
1985 CJ7. LS1/TH350, ARB's front and rear, Warn full floating AMC 20 w/SSBC disk brakes, Ramsey 9000 winch, Custom Paint w/ghost flames
I put the same kit on my jeep, only for one piece axles, from the pics it looks right. The only thing I had to do was change park brake cables, the stock ones would not work. I contacted SSBC, they said to get a Lokar set of cables, so I contacted Lokar, got cables. They function but I can't but enough pressure to hold my jeep. I installed a Mico brake for park brake.
Thanks.
What about the proportioning valve and master cylinder? Were you able to keep OEM?
Let us know how your parking brakes work out.
Excellent write up. Did you need to shim the calipers after the install? Mine needed a small adjustment to center them on the rotor.
It looks like it might take one or so to get it centered. I still have the other side to do and research the parking brake cables. Too much conflicting info out there.
