Starter ATE my flexplate! Need a new one. How do I remove? What Flexplate to buy :(
76cj7chick
Old Time Jeeper
- Solutions
- 1
- WA
- 1976 CJ7 Jeep with a engine/tranny/wiring harness out of a 1988 s10 blazer 4.3l v6 with th700r4 automatic tranny and a cj7 Dana 300 transfer case with Novak adapter.
Complete wiring harness from the s10 blazer. Painted with HOT PINK Pearl paint with standard sized metallic halographic pink flakes. Painted by me -a newb. New rear, front and side three wire LED lights, New parts, new custom dash-by me And a lot of guidance from fellow jeepers and lots of prayers etc.... :p
Boy! It was just before Easter and I finally got my CJ7 running and driving with the gm tbi conversion... I was so excited.. I was driving up and down my street honking the horn and waving at my neighbors..
When all of the sudden I hit a small bump, the engine almost died but kept going.. I heard a little clunking... But all seemed fine.
A few days later I went out to start "him"... And all I heard was GRINDING... tried again.. Still grinding.. (Don't ask me why I tried it again..) More grinding...
After conversing with some family members we figured it was the starter...
I pulled it and sure enough metal slivers were up in the flexplate area... The starter blew the end off but, worse yet the flexplate was all chewed up...
:dunno:
:dunno:
Partially I'm sure it is my fault for not tightening to torque..
I changed out first starter because of the same issue.. However it didn't chew up the flexplate as bad as this time....
I was new to changing starters.. Didn't know much about it and SHOULD have read more about it before attempting to replace the first one.. It looks like it sits too high and needs to be angled downward.. But the po didn't install any shims..
Please give me step by step instructions on how to remove the flexplate.. I will have to do it myself as money is tight.
My CJ7 jeep has the AMC 258 i6 / 4.2l engine with AMC (NOT the gm made) GM Turbo 400 3 speed automatic and Dana 20 tcase (both out of a full sized jeep truck installed by a previous owner)
I can only find flexplates for 360 or 401 with the AMC GM Turbo 400 ... Would it matter if I just got a flexplate for the AMC 258 i6 / 4.2l with a auto tranny? I've read I shouldn't use the flexplate for the 360 since the AMC 258 i6 / 4.2l is internally balanced, so get the no weight on flexplate..
(I am soooo tempted just to sell the engine and tranny and get a gm 4.3 engine and r700 tranny.. But it may take too long and more headaches to sell my parts and get the later parts and then install...):barf:
I may have to get another starter too... Last one was a napa.. I've read that they are junk.. Any suggestions on a decent (and economical) starter that WON'T chew up flexplate teeth (would rather the starter get owned.. But both not getting destroyed and them working properly IS preferred)
Hope I don't confuse all of you....
PLEASE, any and all advice would be sooooo much appreciated....
