Step 1 get running
Thanks for the info. I narrowed it down to the solenoid and replaced it. Got it to turn over briefly but then all power went dead. I'm running off a jump from my other truck so I may have to wait to get a new Batt b4 I can see what else is going on.
The prev owner said spark was intermittent So I need to get the new battery in and clean up some connections next.
Is there a need for a condenser on the coil if it had been converted from points system to a solid state distributor?
Thanks, Jim
When you replace the battery go through and replace or clean all the ternimals and contacts points for the pos and neg cables. Ive seen a lot of starting issues be caused by dirty, oxidized and internally broken wires. verify your grounds are al lthere and solid also.
Thanks, Jim
The condenser is there to cut RFI down.
Mount that neg bat cable to the top starter motor bolt.
