Suspension Stock leaf springs?
ram137
San Antonio, TX
1985 CJ7, 258, t5, Dana 300
Okay, guys and gals, I bought an 85 CJ7 a couple of months ago and have been slowly getting it road ready again and making some upgrades. When I got it, the damn thing handled horribly at anything resembling highway speeds. There was a tremendous amount of play in the gearbox. I replaced it, the sway bar bushings, steering stabilizer, and am in the process of replacing the leaf spring bushings. All of those items were incredibly worn and dry rotted. After replacing those, it’s about 90% better, but I want more :cool:. The shackles on it now are 5 3/4” from center of bolt to center of bolt. I know that will cause quite a few problems with wandering, so I ordered new greasable shackles that are only 4”. My question is, how can I tell if the leaf springs are stock ride height? I’m currently running 31s, and given the extra height from the shackles, it doesn’t appear there is any extra lift. But, how can I make sure?
Have you seen the below thread? Lots of suspension comparisons.
How are the ball joints and tie rod and drag link ends? When I replaced my drag link, tie rod ends, gearbox, and ball joints, I can run 80 with one finger on the wheel and 35" tires. I also replaced the upper ball joint sleeves with adjustable ones to get some camber/castor correction as well.
Here's a link to "Jeep math" to determine various lift amounts:
Calculate Lift Amount
I forgot to mention, I replaced the drag link and tie rod with the heavier duty options also. The original drag link was bent.
Another thread that may help you.
Thank you! I’ll check mine out this weekend!
