stupid question....
stupid question....
Damnitutk
Knoxville, TN
1978 Jeep CJ7 Golden Eagle
ok I have a 78 CJ7 putting a pro comp 2.5 lift on it. I have got the front pass spring off and i am trying to figure out with of the four replacement springs i need to use, none of the paper work has the springs labeled nor indicated which springs are the front or rear. Help?
problem solved... again stupid question, the width of the leaf spring should indicate if it is the front or rear spring.
