Steering Upper Shaft Bearing Question
pschreyer
Holden Beach, NC, USA
1982 CJ8 151
Solution
Yep, that's the race from the bearing. A quick cut with an abrasive disk from a Dremel or another tool will relieve the tension and allow you to remove it.
Solution
Is there a special way to press the bearing into that Teflon ring? I just don't want to break it.
I'm replacing my steering column, upper bearing for the first time. It comes separate. I agreed it very well. I see how it goes in, but do you press it in or give it a good whack? Just don't want to break it, thanks.
A large socket works.
Yep, just fudge it to be implace.
$35.00
  17.5%
