Suggestions
- Featured
- 6
- Media
- 881
- Resources
- 193
- Solutions
- 59
- Central FL
Duane, you cannot flip the current drag link as it is not correct for what we are trying to do. All you need to do is use a device (such as a cut off broom stick) to approximate the correct geometry that is right for your vehicle. We want to eliminate the current drag link you have.
The goal is to leave the tie rod under the spring for clearance, put the drag link over the spring if possible bu flipping the link to the top of the knuckle and having as large as a drop arm as you can use without hitting the spring.
I'll try and find some photos for you.
The other alternative as CW stated is a high steer but that is expensive and requires machine work as well as other hardware changes.
As for the pictures you took. You can use our free gallery (prefered method) -->> http://www.jeep-cj.com/forums/f16/how-do-i-make-my-gallery-category-348/
or just use the 'Attach files' function under the below the 'Submit Reply' button in the 'Additional Options' section...
