Summit - MSD box
Summit - MSD box
Reluctor at dead even with pickup coil core is 'Zero Point'.
The magnetic load of the reluctor arm comes into the coil magnetic field and produces either a positive or negative pulse,
That pulse will stop at the Zero Point when magnetic load is dead even with the coil core.
No matter what the polarity of the pulse when load is moving through the magnetic field, the opposite polarity pulse will be induced when the load passes the zero point.
Negative-Zero-Positive, or Positive-Zero-Negative.
Depending on the module you use (MSD, HEI, DuraSpark, Etc) the module will ignore one half of the pulse and will trigger on the other half.
A 'Drifting' idle speed, moving up & down a little, will often be the wires (polarity) to the coil reversed, the module is getting triggered as the magnetic load is coming in and NOT right after the zero point.
(Guys with combined fuel injection should take note, an unstable idle speed might be as easy as flipping the trigger coil wires to fix)
Rotor Phasing fixes the multi-fire problem, firing more than one spark plug at a time.
By far the biggest cause of out of phase rotors is the distributor gear on backwards.
There are 13 teeth on the distributor gear, no 'Center Line' with an odd number, and when the gear is on backward, you are 1/2 space off on the rotor (between terminals).
This isn't a huge problem when the cross fire is firing both the cylinder on exhaust and the cylinder next in rotation, you probably won't notice.
You are losing some spark energy, but the point of an CDI unit is you have enough spark energy to get the correct plug fired.
When that multi-fire is the current plug in rotation,
AND the plug somewhere between 45 crank degrees and 90 crank degrees (plus advance) with a fuel charged cylinder you are hammering the cylinder that's coming up, not ready for spark yet.
You CAN hammer the cylinder so hard you break pistons, rods, etc.
Normally, you don't have enough compression to do huge damage, but it does accumulate over time.
It's good to correct, and we always check racing engines for the problem since they make a lot more power and self destruct much faster.
Hang a blower on that engine at about 28 psig boost and the Piston/rod will exit the rotating assembly immediately when it reaches peak pressure...
Just a slower failure when it's a low compression engine.
Now, some of you might know I worked for MSD about a 1,000 years ago, when it was family owned and every module did 24 hours of 'Burn In', active testing at full power as a QC test before they ship.
It's not family owned anymore, there are *Some* components made in China, and I can't recommend MSD the way I used to...
I understand they did away with the 24 hour burn in test on modules, and there was an instant increase in out of the box and shortly installed fails.
That's a shame because it was the single most reliable ignition you could buy...
As for plug gap,
If you go past about 0.045", you are going to work the ignition coil to death.
Internal insulation on MSD coils was about 125,000 volts, and that was the best insulation they could find.
Some factory coils, like the Ford TFI coils, could run with MSD... The reason I would snag factory Ford coils when I found them in the salvage yard and could recommend them.
(Ford had a module problem but thought it was a coil problem, made really good coils for years until the module problem was finally found)
When you open that plug gap WAY up, you drive the voltage in the coil WAY up to cross the spark gap.
This overheats the coil, and it breaks internal insulation down MUCH faster.
At about 0.045" you are getting PLENTY of voltage
To drive the voltage up any further is wasting the DURATION (Time) in the spark energy.
With smaller gap, you get a HOTTER spark (Amperage) and longer Duration (time the spark is in the gap) along with sufficient Voltage to ionize the gap so the spark can form properly.
While racers open the pug gaps to HUGE numbers, the coil/plug only has to last ONE race.
Exotic fuels are harder to get burning than standard pump gas, so they jack things WAY up.
The truth is, anywhere between 0.035" and 0.045" is sufficient and keeps the plugs/coil living longer, which IS a concern for us... Not wanting to be stranded without a pit crew and million dollar budget...
The coil is a TRANSFORMER...
The connected power, 12 volts in standard ignitions,
600 volts in MSD modules,
Voltage creates a magnetic field, and electromagnet in the PRIMARY windings of the coil.
When power is cut, that magnetic field collapses (moves) through the SECONDARY windings,
INDUCING (creating) an electrical current in the secondary windings, and that's the one connected to the plugs.
Since the power is cut (open circuit) and there is a Limited size/shape magnetic field, you only get SO MUCH magnetic energy to make electrical (spark) energy with.
It's Limited by the strength of the magnetic field, and the time it takes to collapse through the secondary windings...
So you can convert that magnetic energy into Amps or Volts (not both).
The idea is to balance the Amps & Volts,
Volts ionize the spark gap so the electrical arc can properly form,
The Amps are what sustains the full arc and determine how hot the spark will be.
Opening the gap so you get sufficient VOLTS to ionize the gap, initialize the arc in the gap,
Enough amps/heat to get the fire lit, all on that milli-seconds it takes the magnetic field to collapse is a balance that Nicola Tesla worked out over 100 years ago...
It's not as simple as a lot like to think, but it's not out of common man comprehension either...
The distributor is a lot more complicated than most think, but most can work it out with a little education and some experimentation....
TeamRush...soooo good to hear from you. I’ll give you a call to catch up.
As to your post, I can confirm idle drift with EFI controlling spark due to polarity reversal in a distributor. I had to remove the pins in my distributor and swap them so the harness would clip together and polarity would be correct.m. Solved my drift issues for the most part.
I never did get the motorcraft distributor to work completely with my sniper. Never could get it phased in right when it worked fine with my carburetor. It would run fine then it would surge about 1000 rpm out of nowhere. After a few calls to Holley they determined that - since the distributor runs backwards when compared to the Fords it was designed for - the computer gets into a flood of finite adjustments in too short a time span and it kinda freaks and makes a major correction...hence the surge.
I reluctantly went to a ProBillet distributor and made zero other changes and the problem disappeared.
It's one of those details that will drive you crazy if you don't have all the details...
The more FI systems get installed, the more I run into it.
What *I* (personally) do, and I DO NOT recommend it as a home game,
A $60 Delco Remy breaker points distributor for AMC V-8 (used through '74),
Convert that to magnetic pickup from 70s Chrysler distributors ($15).
MSD cap adapter and MSD Ford style cap,
The Delco phase correcting rotor.
That gives you an AMC/Delco distributor (V-8), rotor phasing correction, and the wide, brass terminal cap along with the MSD blow proof rotor for Delco distributors.
If you operate under 5,000 RPM continuous or 7,000-7,500 flash RPM the Delco is MUCah cheaper way to go and works great.
Since I crawl along most times at idle or just off idle, I don't get anywhere near the RPM limits for bushings, so I don't need roller bearings or ball bearings,
And if you collect enough parts, you will eventually accumulate a breaker points distributor, so even that is 'Free'.
What I like about the Chrysler triggers is TWO (2) triggers will fit on the advance plate, and that means dual/redundant triggers for 'No Fail' operations (rescue vehicles, expedition vehicles),
OR,
One trigger slightly retarded from the first, you can switch to that retarded trigger when hauling heavy loads, lugging the engine on really steep inclines, etc.
We used to do it racing, one trigger for street fuel/driving, one trigger for racing fuel & racing.
Made it a street/strip without doing a bunch of tuning for a race, that little item won a lot of races when guys *Thought* we were detuned for the street...
Nothing like taking lunch money from the 'Know It All' bunch! ;)
The high mountian guys like dual timing at the flip of a switch, going from basically sea level to 12,000 feet can play havoc with fuel/timing, this solved one of those issues.
It's one of those 'Idea' things that can work, not make a difference, or fail,
In these cases, it REALLY worked well before knock sensors, programmable timing, computer fuel injection, etc.
Since I go alone a lot of the time, and I HATE walking out, I do the 'Expedition' vehicle thing.
No sense in having 'Spare' parts loose in the tool box when you can install them...
If the CDI fails, a flip of a switch gets you a $15 HEI module that gets you home with dual triggers and dual coils...
Dual ignitions, dual fuel pumps (mechanical & electric), dual fans (mechanical & electric), dual batteries will get you home when an alternator fails, or a battery fails,
Another idea is the spare tire carrier, mine is a complete spindle, bearings, seals, lockout, anything that regularly fails is right there with the spare tire, no walking because something broke.
Dual batteries & jumper cables with series yoke installed will let you stick/MIG weld,
A jack handle that has an inside diameter of your drag link makes fixing those broken drag links easier, just saw a piece off the jack handle and slip it over the broken link ends and weld it up,
Weld up those stripped out AMC20 two piece axles so you aren't stranded...
Like I said, it's your choice, I hate walking, so I do redundancy and 'Expedition' route.
Some guys will never need that stuff, but 'Trail Rated' isn't 'Self Rescue' rated! :)
