Swap out AMC 360, install AMC 258 Motor mounts?
fastkricket
Albemarle, NC
74 CJ5 258 2bbl engine, ??stock transmission, transfer case and diffs,
631/2 Ford Galaxie 500 390 4bbl
Please Help me! I took the 360 hot rod engine out and sold it. I have a AMC 258 i6 / 4.2l to put back in, but the frame motor mounts and the engine motor mounts don't match up. how do I make this work? It's going in a 74 CJ5 .:oops:
You need to move the passenger side mount. Driver’s side should be in the right place if it was in the original OEM position. If carful the passenger side mount can be cut off and reused.
You may also need to adress the fuel line routing. But yeah just one motor mount is different.
Sent from my SM-S902L using Tapatalk
