t150 issues please anyonehelp
cheftague
west palm beach
79 cj7 jeep renegade amc360. T150 trans Dana 20 and Dana 30
I recently rebuilt my T-150 and put new shift forks in. The tranny seems to be great but when I put the shifter housing on I line the forks up and put the bolts all back in
It wont shift?? Any suggestions would be àmazing. Thx
try this:
take the shifter top off.
align the shift collars (inside the Transmission ) so they are in neutral.
make sure the shifter top is in neutral by moving the shifter around and double checking the forks.
Slide the forks into the collars inside the trans.
gently snug up the top with the bolts, and see if it will turn.
If not, repeat step 1.
I finally got it to fit and work but I'm back to the beginning now. It still won't go into 2nd gear after I replaced the forks. I guess I just assumed that it was just the gear forks. I believe it's the 2nd and 3rd gear Sychronizer. So I'm gonna try that tomorrow. Any tips on how to tell if the Sychronizer is bad? The fork was ate down pretty well but now they're new
Thx guys I got her figured out .fixed.and put back in. She runs and goes into all gears.I am looking for the two little pins that go into the bottom of the shift lever? Anyone know where I could buy some? Thx
If you rebuilt the Transmission yourself, you can use 2 of the old large roller bearings, as they fit. Otherwise, PM me and I will send you 4.
That'd be great thx. Even though I don't know what pm means lol do I need 4 of those pins? I thought it was just two? The pins that hold the shift lever steady
PM means Private Message me your address that way I can send them to you. If I send you 2 and you lose one, then you need another. If I send 4 you have spares.
If you click on Stodg73 a box will pop up click on send a private message to Stodge73 screen will change to where you can do it.
