t176 to 360 pilot bushing and clutch questions
Buuushman
- Media
- 7
- Kihei, Hawaii
- 77' CJ-5, 360 c.i. motor, T-176 trans, D-300 transfer case w\ twin sticks, Dana 30 front, A.M.C. 20 rear w/ 4.10's, solid axles & trac-lok, 2.5" lift Y.J. springs.
Well' I got the T-150 and Dana 20 out, but I'm having trouble finding the correct pilot bushing to mate the T-176 to my 360. The 360 is from a 79' and the t176 is from an 81' if it matters, and if someone could come up with a part # for the bushing it would really help. Also the new clutch that I picked up is a 11" borg & beck style lever pressure plate type instead of the 10.5" finger spring style, it bolts right up but I'm not sure if the clutch fork and older spring clip and plate type release bearing will work, or if I'm looking at getting a newer style clutch fork that will use the release bearing that came with the kit.
Kinda tough questions, and I'm sure I'm forgetting stuff, but that's what I've got for now.
Thanks in advance,
Bush
Thanks in advance,
Bush
