T18 reverse switch help
CJ007
Old Time Jeeper
Peoria, AZ
83' CJ7-35's, granny T18, clocked, locked, 456s, D30 20 trussed- stitched-heim traction-1 piece shafts, CV dshaft, quick discos, xtended shock mounts, SOA, revolvers rear, braided lines, herculined, hand throttle, AMC saddle bags, rebuilt 258, D300.
Anyone know an easy fix or where I can find a reverse switch for the Ford T-18 ? T-4 is too large and from what I understand the ford only had one terminal. Oh yeah, they were still using the T-98 cover this year if that makes any difference. Thanks!
Sorry no help but I can say it is unlike my Jeeps original equip T-18 , mine is unthreaded and pressed in from the rear and not on the side as your pic shows.:wtf:
Keyword Ford :D adapted to Dana 300 . Pretty much same, granny geared 6.32:1
Do you know what year and model Ford your T-18 came out of?
67' F250. I picked it up from CL. The guy had bought it from Luke AFB to use for parts on a restoration of a shortbed for his son. I had to pull and paid $50. Another $600 later and its getting there. :D
Oh yeah, 2wd version. He said it was use to pull stuff aroung the base and it had the PTO, passenger side. I pulled it though as it would get in way of front driveshaft.
Anyone know an easy fix or where I can find a reverse switch for the Ford T18? T4 is too large and from what I understand the ford only had one terminal. Oh yeah, they were still using the T98 cover this year if that makes any difference. Thanks!
I run a Ford 2wd T-19, it used the same switch as the factory 79' CJ T-18 .
I bought my switch from Morris 4X4 & got a 10%
www. Jeep-CJ.com discount.:chug:
I run a Ford 2wd T-19, it used the same switch as the factory 79' CJ T-18.
Right on! I picked one up today at a local parts house. :notworthy:
