TCL-1 Transfer case fluid
Fastatv
Whitesburg, TN
1976 CJ-7, 360 V-8, Turbo 400 trans, Quadratrac, Dana 30 up front, AMC 20 in rear with LOKKA locker, Otherwise stock...and rusty, but FUN!
I've searched on here, and the web without any results for a substitute Transfer Case fluid TCL-1 for my QuadraTrac full time Transfer Case . Do any of you know of an obtainable substitute? Thanks
Thanks for the link, nice site. I was hoping to find an acceptable substitute, something I could purchase at one of my local box stores, an ATF possibly, or some type of hydraulic fluid. Thought someone on here may have already researched it and found a substitute.
An important issue is that the QuadraTrac has a Limited slip differential in it. If you use a regular oil you also need a Limited slip additive.
Thanks JR, very informative link. I may just mix my own as the link indicated. Looks fairly simply, if their "potion" is correct. And may mix up about three quarts for $12 or $13 bucks. Thanks again!
