Build Thread The one off
weasle50
Coatesville Pa
1990 XJ 5" junk yard lift on 31's for now.
1980's CJ basket case.
You had your motor mocked up in the rear :) We like pictures, It's looking good dude!
Yea there was no cross memeber on the rear. We ripped it off while moving the jeep into that location. We were beating on the bolts for the springs so hard that the rust that made the frame look intact fell onto the ground in one long line from front to back on both sides of the frame.
I tried to take pics of each step. I cut the top where the window frame rests of on the cj to get the two ports where the defroster goes. After cutting the center portion out i noticed that i had cut it too short. so i cut both side back to the hinges. I then welded it back together. I put tape on the top found center and measured the distance to make the cuts. I did the same thing to the cj, trimed and mounted to the yj and welded it back in.
I also tried to get the time line of the pics correct.
You've been busy.
Looking good. I like your old frame. :eek:
WOW if thats not a ground up build I don't know what is!! Looks like you've done alot of hard work!!!:D:chug:
Nice work. I'm only about 15 minutes down the road from you, so if you ever get in a bind and need a hand... :chug:
