thinking of doing ford shock tower
dalefan88
Crazy Sr. Respected Jeeper
thanks olddog. i think i found my next project when i get paid lol.
What all did you get for the $54? Can I see some pics of this Dalefan? I went ahead and pulled my old shock mounts off, eagerly anticipating getting started getting the frame ready to go.
I see, good thinking on the plate. I will probably weld mine in. Do they bolt right into the same location, or are you making new holes?
well i got one side done so far. the only thing i think is wierd is that it makes the top of the shock lean out further than the bottom. is yours like that olddog? it looks like your lower mount is different from mine.
yea the top does lean out a little further.
My shock mount was on the bottom spring mount and I had it moved to be welded on the axle, when I did the u-bolt flip.
. Then you can it take it for a shake down run and splash in some puddles.Just pretend that you are doing a trail repair, and you have to get it done. Then you can it take it for a shake down run and splash in some puddles.
looks sweet but have to wait for the wife to get home to test it.Did you get your camera fixed yet so that we can some pics?
