Third proportioning valve leaking
bwmetcalf
Wimberley
'79 cj7, amc 360
Hello,
Can anyone recommend a proportioning valve for a 1979 CJ7 that won't leak? I have tried three of the following https://www.morris4x4center.com/disc-drum-proportioning-valve-aluminum-mbm-pv2a.html and each one has started leaking from the metering valve cover. For the third one I rerouted the brakes lines and mounted it next to the master cylinder to get it away from the heat of the exhaust in case that was causing them to leak, but this one is leaking after about 4 weeks.
Thanks.
I haven't had any issues with mine from Inline Tube. P/n vml101.
