Interior Thoughts on bumpers, spare tire carrier & tire size...
UncleMike
Shrewsbury, MA, USA
1979 Jeep CJ-7, 5L
Trying to wrap up Phase 1 of my 1979 CJ7 rehab, and my target is to wind up with a lightly modified but largely faithful restoration. Mods i am open to are safety related, or intended to correct original Jeep issues, but really not looking to build a wheeling rig, and just plan to putz around town and drive at the beach. Body and frame are original, with no real sign of modifications or body work. Other than some surface rust, no rot or rust. When i got the Jeep, it had a poorly done suspension lift and body lift, and 35x12.50s, tube bumpers, electrical gremlins, guage/switch issues, etc...ran all over the road due to springs and shot steering column/shaft.
With help from this forum, i have since rewired much of the chassis, replaced lights, all switches, gauges (new speedhuts), rebuilt hte heater box (with blazer fan motor upgrade, MTS cables and original, but recored, copper/brass core) and did the wolff steering column bearing and borgeson shaft. Just ordered a mild 2.5" rough country lift, 1/2" tellico shackles and 15x7 crager nomad II (closest i could find to stock) wheels. Tracked down original lever style doors and a few other odds and ends.
Now it is time to think about tire size, and i have a few questions.
First, it has low quality tube bumpers and no spare carrier. Unless some of these came with no spare carrier stock, PO filled the holes (he did a frame-off about 10-years ago). My preference would be to go back to stock bumpers, stock (or close) spare carrier, and bumperettes, but not fully convinced quite yet since the rockcrawler style bumpers are just a slight deviation from OE and don't look "new-fangled". I would like to add a warn 8274 at some point. LIke i said...not looking to be fully stock, but would like a look that is close to original and looks like it was modified back in the 70s/80s...classic.
So, first, tire size. Either going 33x10.5 or 31x10.5s. i could run 33x10.50's with the planned 3" lift...but i am told i would need to keep hte body lift. I'd prefer to go back to stock body bushings as i don't like hte look of body lifts. First question...can i run 33x10.5s with just hte suspension lift? Second consideration...weight and size of spare tire on stock carrier...thoughts on this? Third consideration...drivability...not going with mud tread, and likely just a BFG A/T.
So, as i ponder all of the above, i wanted some thoughts on the tire size, body lift and rear bumper/spare carrier, since it all relates (in my mind). I could go with a bumper with integrated spare carrier, or go back to stock...but, will i have issues down the road with either the 33x10.5 or 31x10.5? Will i have issues running the 33s without the body lift? Would love to get some feedback and pics from anyone with ideas or experience around this...
I have 33x10.50's and a 4 inch lift, no body lift. you might be able to do it with 3 inches ans possibly some minimal body trim work. I have never stuffed my tires into a body panel, not for the lack of trying as I rock crawl.
I should have posted about the tire carrier/bumper stuff before. My bumper has a built in tire carrier/hitch noting mounted to the body the carrier portion also doubles as the home for my Hi Lift jack. There are many bumper/carriers combo's out there. I would avoid fabricating a hitch mount to a tube bumper unless the tubes are very thick wall and can handle the strain of towing.
I have the Warn w/swing out tire carrier with the 2” hitch. Don’t think they want you towing with it, but I’m sure the basket would be good. I’ve had it 15-20 years and like it. I’ve heard the price has skyrocketed but don’t know as fact.
One more question...my jeep doesn't have a sway bar and the leaf plates did not have the exta stud...doesn't appear to have been cut down, nor can i see where there are factory holes for hte bushings on the frame. Anyone put a sway bar on a 1979? Is it as simple as changing the plates out? I don't know where it is supposed ot mount on the frame, but there are unused holes so maybe a set of those? I'd like to do everything i can to get this riding nice and safe on the road.
I have no sway bars and its fine I corner slow by nature anyway.
Uncle Mike,
I have a factory anti-sway bar (aka: sway bar) if you’re looking for one. Also, the front spring plates which have the correct studs, to which the links attach to.
Pay for shipping and you can have em.
Uncle Mike,
Thanks for the offer!!!...happy to pay the shipping, but won't need the spring plates, as mine needs the studs for the shock and sway bar link, which i have just purchased. Sway bars appear to be all the same, but i think the shock mounting locations changed in later years. I can definitely use everything else, just let me know how to connect to get cost, venmo, address, etc...What i could also use if you have the info is a pic of where these mount exactly on the frame, or a measurement from something standard (like bump stop)? Mine doesn't appear to be set up for this from the factory (although can't be sure until i have brackets in hand) so assuming i may have to drill some holes.
Every bit of this is subjective and dependent on what you want to do with your jeep, I personally love a stock ish looking CJ as well and think they look great with 33s and a mild lift
That being said, if you have stock highway gearing you will accelerate slower and your 4lo wont be as slow as it used to be which can easily be overcome with gearing
Pay attention to your drive shaft lengths and pinion angles
I built a very similar rear bumper for my Jeep i love that look and it’s definitely better in a collision than the stock bumperretes….. i need to install my bumper one of these days as well
I went with the Dirtworx bumpers front and back. Came raw metal so I had to sand and paint but the cost was way less than Lod and the construction was excellent
Thanks. Sent an email yesterday evening.
and some of the front. A direct remove and bolt on with hardware supplied. Lined right up without a fuss.
I like those bumpers
