Throbbing, pulsing clutch pedal
b3uhbp
- Arlington, TX
- 84 CJ7, 258, T5, Dana 300, Dana 30' AMC 20' Weber 32/36 carb, DUI HEI ignition, 2.5" suspension lift
Recently I replaced the clutch on my CJ7 . Also replaced rear drive shaft and u-joints and Transmission mount. Everything seems to be working very well, but when the engine is running and I begin to push on the clutch pedal and the throw out bearing gently engages the pressure plate I get a throbbing/pulsing in the pedal. Once I fully engage or fully release the clutch it goes away. Wasn't there before. Any ideas?
