Throttle linkage bracket - weber 38 install help needed
Flex BT
Chesterfield, VA
1981 CJ7. I6, Weber 38/38 with TEAMRUSH upgrade. T5, Dana 300TC, Dana 30 / AMC 20, True trac w/ 4.10s. 33" All terrains
Blue and rust colored.
I got fed up with my Weber 34dgec (discontinued re-branded solex piece of junk) and bought the weber 38 dges. Installation was going swimmingly until it came time to hook up the throttle. The 34 dgec (installed by the previous owner) replaced the stock throttle linkage bracket that mounts on the intake manifold with a little bracket that relocated the throttle cable to the other side of the carb. Going with the 38 assumes I have the original assembly and has stopped me in my tracks. Does anyone know where I can get the linkage bracket that will work with the 38? I looked all over for a stock replacement and couldn't find one anywhere :( Here's a picture of where I believe the stock bracket mounts.
Sorry to dig up a 4 year old thread, but I'm having the same issue, what did you end up doing to find one? get lucky at a pull your parts?
I'm pretty sure I have what you need. Pm me a pic of it just to be sure
Pete
wow such a shame that no one responded to the OP :eek: if Pete dosent have it Collins bros should have it
I checked Collins Bros and didn't see it, but that site is an awesome resource! thanks for pointing it out to me.
Call them they sell used parts as well, probably will be high priced just to warn you, Dennis has to pay for all trips around the US with Gas Monkey
Hey here I am!
I think I ended up having to take the bracket from the 34 and turning it upside down & backwards, then moving the little knob around on the throttle on the carb. If you still need help I can try to snap a picture when I get home.
I did the same thing. Used the 34 bracket upside down and bent it to work.
I am about to drop a rebuilt Iron Duke into my 1980 CJ7 . I was initially going to replace the carb with the weber 32-36 but after reading a little bit on the weber 38, i may go that route.
Im not finding much info on this carb other than this thread. Does anyone have any comments about the weber 38, either positive or negative?
Thanks,
Chip
After messing with both the 34 and 38, don't go down that road. The 38 has the same problems that make my Jeep stink like gas when you let off the throttle and my wife hates riding in it and therefore resents my second love. Don't be like me, buy a Holly. Everyone who has one loves and recommends it. I wish I could go back in time.
Also, I had to send my first 38 back and just recently had a starting issue due to the throttle plates sticking.
Thank you. That's excellent information. Which model Holley do you recommend ?
Unfortunately I'm unqualified as I've never had one. I forget the model everyone talks about around here, might be 4400 or something. Honestly I'd call Holly and see what they recommend. What most have for their i6 might be too much for the Duke.
