Steering Tilt steering column, not factory bearing?
Jaymon
Georgia, USA
80 CJ5, 258, D300,AMC20, D35
:welcome:
That is a GM column which AMC used for many years.
You need to remove all the balls and then pull. With any balls in it just applies pressure when you do not want it.
Thanks for the reply, I'll see if I can fish them out.
Yea, the ball bearings increase leverage on the inner race when pulling from the outer sleeve.
Im in the same boat thanks to wanting a functional turn signal and ignition lock... 😆 🤣 😂
Just got rebuild parts ordered for whole column. Also even with new ignition lock cylinder cannot get it to go into lock position to take out key, so hopefully the column rebuild fixes that.
Same problem. Seven years ago I had a shop rebuild the upper tilt column, and replace the steering shaft. I think it cost me almost as much as I paid for my CJ5 , but I've never had any problems since.
