Timing Cover ID help needed.....
project74
Upstate SC
1974 CJ5, 304v8... purchased 8/8/11
They look different to me....castings are different.
I would be suspicious of one or the other. They are both obviously AMC V8 timing covers, I guess you could try fitment and see what happens. My concern would be oilpump shaft tolerance with the dizzy. Have you swapped pump gears with the new one yet?
Hi Cjim7,
Oil pump gears transfer fine, bolt holes line up with block and waterpump, the only difference I can see is the index marks and the horizontal barrall shape directly over the index on the blue one...not on black one...It has a hole thru it as if a pointing devise would fit in there?
I dont want any issues with setting correct timing....was hoping someone would know for sure which casting numbers was correct for my 74-AMC 304 ?
The blue one would be the correct one, IIRC they changed the timing castings in 75. The blue one is the same as the one one my 73 AMC 304 . Other than the timing marks they are the same.
O.k., Upon looking at these further I see that the timing indexes are different but the same as far as clock position, so I decided to use the blue one because it was in better shape...but...I have just noticed two very bad cracks in the side of the cover that go all the way thru the edge and other side.....can you say SCRAP!
Guess I'll use the black one unless a better one comes along.
Thanks to all who responded.
Ed
Hey jeepboy45,
I ended throwing the blue cover out, installed the black one. I have yet to fire the motor. I have rebuilt all mechanicals with engine, Transmission , transfer, axles, brakes, fuel system....but am now cutting into body to repair rust panels...I might get to turn it over by spring...just gonna keep rotating crank once in a while until then.
Ed
thanks for responding project74...
I'll try posting on a new thread and see who pops up..
good luck with the rest of your project and please keep us informed when you finally decide to turn the key... Everyone gets excited when another Jeep breathes to life again!!
brian
$45.00
  22.5%
