    Thank you for your support!
Timing help please
Timing help please
Bog Dog
Kansas
1984 cj7, 258 I6, dana 30,amc20
84 CJ7 AMC 258 i6 / 4.2l carburated, what should the timing be and what is the firing order? also do these go clockwise or counter? thanks for the help.
Umm... Here ya go... [url="https://www.google.com/search?num=100&hl=en&safe=off&site=&source=hp&q=amc+AMC 258 i6 / 4.2l +firing+order+&oq=amc+AMC 258 i6 / 4.2l +firing+order+&gs_l=hp.3..0i22i30.589.15942.0.16807.21.12.0.9.9.0.119.919.11j1.12.0...0.0...1c.1.8.hp.oahhZ-W55m4]Google AMC 258 i6 / 4.2l firing order[/url]
1-5-3-6-2-4
Clockwise.
got the mechanical part, just needed the specs. thanks, you guys are great.
3 weeks, 4 days, 0 hours, 2 minutes, 46 seconds
