Tranny fluid removal help
1984 CJ7
Portland
1984 CJ-7, 258 (rebuilt), 5 speed (rebuilt), softtop, Goodyear DuraTrac's
What is the best way to get it all out? Use a suction tube of some sort? It's weird that the drain plug is not on the bottom of the Transmission . So, when you drain it, it leave a lot still in the sump.
You sure you're looking at the drain plug? Ive never seen a Transmission that you have to pump the fluid out of.
Well, the drain pung is not at the very botom passenger side of the Transmission . So, a little will be left in the sump.
