Tranny leak????
Tranny leak????
ftwflh
Crossville,IL
1976 CJ 5, 232 6cyl 3spd lots of rust,good frame,Dana 44s w/373 gears,ProComp 4in lift kit
Do you own a pressure washer? Thats where I would start. Then add UV dye to your components.
Little cold her in IL right now to drag out the washer.I hate to drive it until I find out how and why the Transfer Case is gaining fluid and tranny is loosing it.Filled the trany and drained to T case last week and drove about 10 miles and the Transmission is low and T case over full again.
I know there is old build up that needs to be cleaned off but I have found fresh oil around the clutch lever boot and between the tranny and the Tcase.
No oil around the oil pan or running down from valve cover.
As of right now I have 20w50 oil but am changing it to 10w40 after I fix this tranny oil thing.
