transmission choice opinions
with the peek torque on the 304 being about at 2500 RPM I can see where this is a good chart for you. I am thinking at this moment that with the 4.2 the prime RPM range may be a bit lower. Closer to 2K. This may be some sad rationalization to justify my 3.54 axles but this is my opinion for the moment at least.:D
I don't think your far off IO, when I ran a "Four Deuce" with a T-18A.
I ran 3.92 gears with 33" BFG M/T's.
The thing with the chart is, it doesn't allways work out as planed. For instance I run "33" inch tires, they measure more like 31 or 32 at best. But looking at the chart, it says I'm running more like 30's. (2900-3000 rpm).:confused: But hey thats ok cause my 350 is just starting to purr than.:D
Has anyone else tryed using the chart and if so how close was it for you?
The old math way is... RPM = MPH X gear ratio X 336 divided by tire dia.
Hey Dog,
Have you tried measuring from the center of your hub to the ground, then take that (number X 2)= Real Tire Diameter, not advertised diameter.;)
Horn, thats where I came up with 31-32" depending on air pressure,
at 12 lbs They are more like 26's :D
Back to the chart or formula I think me haveing an auto (torque converter)screws with the numbers some. Thats why I was wondering how well it worked for other guys.
Rodger that, over.:chug:
Airing downs two fold benefit;
Better ride & lower final drive ratio for off road.:cool:
thanks for the link it helped clear up some questions i had, it is looking like i might be looking for a chevy front axle now as some already have the high steer knuckles on them and they will closer match my rear axle width, does anyone have advice on what year trucks i should be looking at and what type, has to be 8 lug
hey guys sorry to hange the topic but still looking for front axle advice if anyone has any?
