Transmission Mounted incorrectly?
lemmons1
- Media
- 3
- Houston, TX
- 84 CJ 7, all stock as far as I know... just bought it 4 days ago and it needs a lot of work.
I have recently purchased an '84 CJ7 . This is my 1st Jeep to own. It needs a lot of work. I have many things I need to do to it to get it running, but I have noticed that the Transmission and Transfer Case have been moved back slightly.
My question is, do any of you have an idea what this was caused from? I have done some research and it appears to be a T-5 Transmission , with a Dana 300 . You can see in the pictures that the floor pan has been bent down and the lever to the Transfer Case has been rubbing against the floor. I do not have a picture of the clutch linkage, but it too is slanted toward the back of the vehicle from the fire wall where it mounts over to the bell housing mounting point.
I have posted 5 pictures.
Any help is greatly appreciated. I have never posted to a forum, but have read many, many threads and posts on a number of topics.
Thank you.
Thank you.
