Transmission Mounted incorrectly?
lemmons1
Houston, TX
84 CJ 7, all stock as far as I know... just bought it 4 days ago and it needs a lot of work.
Welcome to the forum neighbor :chug: your jeep looks normal to me, thats similar to what my tub looked like when I got it and it had the T-4 /Dana 300 combo I am willing to bet you have a combination of sagging/dead body mounts, dead/sagging engine mounts and dead/sagging Transmission mounts that is causing your problems but I cant tell for sure without being there to see it. your radiator fan should not be more than 1 inch away from your radiator, if it is it may have shifted back
#56 will get you new motor mounts and tranny mounts with a new torque limiter bushing for the Transfer Case , that should stop the transfer case shifter from bouncing off the floor and hopefully move the engine back to where it is suppose to be Jeep AMC 6-Cylinder 4.2L (258ci) Engine Parts
item #13 will get you new body mounts and the tub might sit a little better, just be aware that the bolts are bad about breaking off because they are rusted to the nut so if you dont want to tackle that you will probably be ok and you will need to get the new bolts at your local tractor supply
Jeep CJ Body Parts by Morris 4x4 Center
let us know how it goes
Thank you gert! I am ready to start tearing into this machine. I will replace the 3 mounts and see if that helps. When I have turned the engine over in an effort to start it, the motor and Transmission shake with each rotation it seemed. The body bushing kit is something that I know needs to be replaced. The bushings underneath are cracked in many places.
Thank you for the information. If you find out anything else, let me know. I appreciate it!
Considering I am new to this type of communication, I will be posting more of the build as I go.
Thanks again!:chug:
