TREX 21 Gallon Tank
Super8mm
Silver Supporter
Bronze Supporter
Grapevine, TX
1980 CJ5, 4 cyl, Borg Warner/Ford SR-4 4 spd, Dana 300 transfer case.
Start a heart transplant mid November with LS1 and SM465 :-)
I installed the standard size in my 77. Works fine. Not sure if it's made by the same company but it was also made in the U.S. Just pay attention to the tail pipe. The heat may soften it and over time it may become brittle.
Thanks, I will keep that in mind as I will have to have new exhaust built for the LS1
When I do my engine swap I will need to drop and install a fuel pump so I was thinking about adding a larger tanks.
I found where TREX has a 21 gallon tank and was wondering if anyone else has tried it and if they like it.
1978-1986 Jeep CJ 21 gallon plastic tank - T-Rex Auto Parts
That is the MTS tank upgrade on the T Rex page. It is the same tank I am going to install and am sourcing the parts now. One thing I have found out is don't let the illustration fool you, not all the parts on the picture are in the kit.
T Rex does have the tank listed for $10 less than I paid Quadratec for the same thing though.
Thanks, are you going to put a skid plate under it?
Yep, the kit is supposed to come with exteders so you can use an OEM skidplate for the 15 gallon tank. At least that is what the MTS site says.
Sent from my ALE-L21 using Tapatalk
OK, Thanks
Just got the email today that my tank shipped so I should be able to tell you in a week or so what all comes in the kit.
Thanks, I will appreciate that.
I used the MTS tank on my Jeep and that tank is thick I like it, I bought the YJ tank it came with the pump, pick up straps and gasket
Sent from my kitchen using Tapatalk
Hot my 21 gallon MTS kit on the mail today. It has the tank, top strap, and skid plate extensions in it. That is all.
Hot my 31 gallon MTS kit on the mail today. It has the tank, top strap, and skid plate extensions in it. That is all.
Great, let us know how the install goes. :D
I know I will have to replace the fuel pump when I do it as the LS1 if a injected motor
I already have new nylon fuel line, and fuel filler hoses, neck, and bevel, and secret squirrel Marine access hatch. The only thing I am missing now is the side straps for the tank. I am going to order them today and see how long they take to get here. As soon I have everything here I will put the tank on. The PITA is it takes forever for parts to get here from the US.
I understand the shipping, I order stuff from Scotland, guess they just dont understand we needed this stuff yesterday "LOL" :chug:
I know right :)
