Engine Troubles with my 86 CJ7 258 bottom end with a 4.0 top
Jeepjkgrrl
East Coast
Current
86 CJ7 258 w/ 4.0 top. D30
JKU
Past
77 CJ7
80 CJ7
:welcome:
Why do you think you need a drivetrain swap? By your above post I was under the impression that was complete and it's down to wiring.
Well the Transfer Case still is held together with JB weld and foam… it’s obvious that the person before me who did the top end swap and obvious other ā€œmechanicalā€ stuff that it might be better to start fresh or just find the electrical problem the issue with the steering column or the radiator…
I misinterpreted your post, I thought you had replaced the TCase. A used Dana 300 is a pretty easy swap. Do have the capability of doing that in your drive?
What steering column and radiator issue? Your CJ has a GM column so there are parts everywhere.
Some pics of the Transfer Case and its "repairs" would be helpful. JB weld on a low/no stress point might be fine for years, but I am having a hard time imagining what expanding foam is doing. Personally, I would run what you have and just fix what is needed, unless this is some kind of restoration.
1st - That is a Jeep / GM non tilt steering column with a Pontiac horn button. Do you want to rebuild it or replace it? It is already partially apart but some of the bearings can be a PITA to change without the proper tools. There are many column rebuild company's. Either buy one or send yours in..
2nd - Your Dana 300 if OK as stated HERE as long as the JB weld is in a no stress area. Vague pictures do not help with evaluations or recommendations. Pleas give us as much information as possible.
I would like to rebuild it to keep everything as original as possible.
Understood, you can rebuild it yourself or send it out and have it rebuilt and returned.
Either way it needs to be pulled from the Jeep.
Unless I'm mistaken, the pic with foam and black goop appears to be the top of the Transmission top cover. When you tore it down to rebuild it , was it cracked? Still trying to wrap my head around the expanding foam and what someone thought it would do for them.
