Turn signal problem
dtrojcak
I recently acquired a "new to me" 1978 CJ7 .
It needs a little work to pass inspection and be street legal.
All of the lights, with the exception of white reverse, work fine.
Headlights, both high/low beam, brake lights, and side markers all work.
The problem is I have no blinkers. Turn signals and 4way hazards do not blink.
I've replaced the flasher that plugs into the fuse box with no change.
I've purchased a new turn signal switch, but I can't figure out how to remove the old one from the column yet.
I did hook up the new one, but the blinkers still don't blink. I'm not sure if it has to actually be inside the column for grounding purposes or not though.
I did put a test light and a DVM on the harness.
The horn wire is constant 12volts.
The brake wire is 12volts when the brake is depressed.
None of the blinker wires get voltage at any time, no matter what position the blinker switch is in, including turning the hazards on.
I need advice on what/where I need to check next to figure out why my blinkers don't blink.
Thanks for any advice.
