Upgrade the fuse panel?
nctom
Asheville
77 CJ 7, 258 i6, 3 speed
Is it possible to upg the fuse panel without doing the whole harness? I want to move to blade fuses but don't need to rewire the whole rig. Thoughts?
actually that would not be that hard of a project
you just need to research a bit about your penal, the one you want and also changing some systems over to C/B and relays
would improve the Jeep
Any idea where to buy a panel? I checked painless, quadratec, morris- they had harness kits but not just a fuse block. Thanks!
I didn't replace the panel in y CJ but this one from a 97 XJ would supply all the circuits you need and a fair number of relays as well. cruising the pick your part could give you the system you are looking for.:cool:
I got mine from West Marine.
BLUE SEA SYSTEMS Fuseblock at West Marine
Electrical Fuse panel
