    Thank you for your support!
Useful Info thought I'd share
Brook, you have created a very good resource here, thanks and keep it coming
This is a link to the Fire Prrof Build:
06' LJ build...Fireproof - JeepForum.com
It's a LJ but has alot of great info that can be carried over to CJ's,
one of the best most inspirational builds I've seen, the LED lighting used in the tube fenders, the tintable raptor lining, other details you just don't see in alot of builds.
Well worth a read.
I need a lesson.
I know my "84 is a CJ7 .
My Alldata tells me that 86 was the last year of the CJ.
It makes no mention of YJ,LJ, etc.
They are all just Wranglers 86-now.
Could you break down the years to models?
Maybe i missed the link?
Thanks to the pros!
87-95 is a YJ, 97-06 or 07 is a TJ, and the present model is JK. Pre 87 can be a bit of a jumble, i am sure someone had a full list out there.
I need a lesson.
Thanks to the pros!
Here ya go:
Jeep - Wikipedia, the free encyclopedia
Like most things there are gray areas, like the yj to tj years.
