using a motor stand
using a motor stand
lake1985
sherburne, NY
1974 CJ5, Stock. Want to fix it up and drive it. Engine and Transmission work fine, body ruff. Frame is very good.
Trying to decide if it is easier t just replace tub, than try and repair all of the problem areas in original body, i.e.. bad floorboard, tailgate, side panels , windshield bracket, you get the idea.
I have a motor stand and am trying to get the brackets to line up with the mounting holes on my 6 cyl. 1974 CJ5 motor. I cant seem to make them line up. Does anyone have any advice or experience with this kind of problem. Thought while I put a new tub on it I may as well rebuild the motor.
depending on the stands some bolt right up and some are a PITA. I have 1 of each. loosen every thing up. tighten the motor bolts then tighten the bolts on the stand.. it will take some playing with.
I will give both ideas a shot. Thanks
Be sure the stand is designed to handle a 6 cylinder. They are normally longer than a V8 and when built out on the stand there is a lot more weight out at the end and it could make the motor stand unstable.
Might be a toe breaker.
$35.00
  17.5%
