V-Belt Numbers Please. 84 CJ7 W/ p/s and a/c.
1984258CJ7
Central WI
1985 CJ7 258 T-5 D300
Not sure. Got some from autozone today. Not sure if this is routed correctly? Thanks guys.
i would say thats pretty close to correct, the compressor needs a longer belt to go from the crank to fan to compressor and you should be set from there. the alternator and compressor pulleys will turn with the engine, the compressor has an electric clutch that engages with the pulley to get the compressor to pump Freon.
it appears from your photo that the only way the alternator will turn is if the AC is on. On my 258 the PS runs on the innermost belt, the AC on the middle belt and the alternator on the outside belt.
Lance
the compressor pulley will turn anytime the belt moves, it has an electric clutch built into it to drive the compressor when the ac systems asks for it. Therefore the alternator will turn as well.
