Valve Cover change to Aluminum ?
dvandebrake
Diamond Bar,Ca.
1995 Toyota T100 (awesome veh.)
1986 jeep cj7 with in-line 6 cyl. 258 5-speed manual trans.
Hi all,
I need to replace valve cover and am thinking of purchasing a Valve Cover by Omix-Ada. Kind of pricey but would like to go to metal. Anyone have experience with this product? Is it ok to this valve cover. Also I see this valve cover requires drilling? What the hell I need to drill into block? Doesn't sound like fun. Any alternatives.
you might need to tap the holes that are already in the head. i have one of those valve covers and its ok but i'll warn you becareful tightening the bolts they will crack fairly easy as they're cast aluminum.
Thank you for the info. Will go with Omix-Ada Aluminum
