water pump and accessory pulley
thistle3585
- IN
- 1979 Jeep CJ5 with '72 304 V8, MC2100carb,T150 trans, AMC20 rear diff with locker, Dana 30 front diff, Dana 20 Tr Case, Procomp Springs, Gabriel Ultra shocks.
Replaced the timing set and my pulleys don't line up with the power steering pump. They line up with the alternator. I had an occasional squeal before I did the replacement but it went away after it warmed up a bit. I'm wondering if the power steering pump needs shimmed somehow or if I should only run the belt around the accessory pulley. I'm not sure what changed. Wondering if I may have the wrong pulley. The engine is a 72 but Jeep is 79, so I may have used the 79 pulleys when I swapped engines. Was there a difference?
