What axle tool do I need?
cjTango
Southern California
1975 CJ5
Eng: I6 one-barrel 258 cu in (4.2 L)
Trans: T18
T-case: D20
Axles: D30 (F), D44 (R)
Is that a full floating rear axle?
Can you post a picture that more clearly shows this nut?
Also-PLZ post a picture of the axles diff cover so we can ID the axle.
Ahhhhh, better pictures make it obvious it's not a floating axle. At first I thought the dark center was a hole rather than the simple end of your axle shaft. You have a Dana 44 . No super special tool is required. You can use an slide hammer, You can borrow one from Autozone. Or take your brake drum turn it backwards lightly set the lug nuts and use the drum as you would a slide hammer. All you are doing is unseating the bearings and pulling the axles from the differential. There are no axle clips or retainers in the differential.
??? Cell phones and their upside down pictures. Sometimes having pictures oriented with the floor down at the bottom can make a difference.
Confirm you have removed the 4 bolts behind the hub.
Just wrap a chain around the hub, and jerk it out.
Thanks LG & Hedgehog. :chug:
I'll be giving this a shot when I get home this evening. I was stuck thinking that the entire painted center-piece had to be rotated.
I haven't removed the bolts yet, though it looks like there are actually 6. I'll double check.
I have a slide hammer I'll put to the task when I get those bolts out.
Will post the follow up.
Thanks.
My mistake, since you already stripped the brake components I thought you had stripped the bolts as well. Folks like Lumpy have done it so often removing the bolts becomes automatic with no thought. .... Yes, there are 6 bolts, two are at the way top and easy to miss.
Okay gents,
I got the axle out.
Now, any tricks of the trade for getting that bearing off? (I’ll try posting pictures again tomorrow morning, they don’t seem to want to upload tonight.)
Also, the new one I picked up doesn’t have open races like the old one. Is that a problem?
Thanks again.
I don't know how it is done, but new bearings are one unit race/bearing. When they are used and run the race disconnects from the bearing. It's supposed to do that. The old race is tight but loose and can be removed relatively easily. Removing the bearing from the axle is a different matter. They should be pressed off .... Or .... do as I do, cheat. Carefully cut the big metal ring and bearing off with an angle grinder cutoff wheel. You don't need to cut all the way through the center race. Score it deeply on two sides, they are brittle and pop it off with a chisel. Setting the new seal, bearing and steel ring is another story. To do it right you will need a press .... or drive it on with a pipe and BIG hammer. I recommend finding someone with a press.
Another method:
Using a 3/8" drill bit, drill half way into the bearing lock ring from the side.
Don't drill all the way thru and into the axle shaft.
Usually half way is enough.
Then take a large flat blade chisel and big hammer and strike once on each side of the hole.
This will split the lock ring and it will easily remove by hand.
However you remove the lock rings, discard them as they are not re-usable.
:agree:
Bit 'caveman' but I have done it many times this way.
Use a section of pipe to seat the new bearings.
Take pictures of the bearings as the are now installed, to be sure you get it 'rite'.
Seat the bearing first, and then the collar.
Make sure to replace the outer seal too.
How do I? Oil seal
