Diff What came stock for rear in 81?
Differentials
Kingofwood
upstate ny
1981 CJ5,350
1995 YJ
Hi fellow Jeepers>if iam in wrong stop please guide me in wright direction Thanks
I have a 81 CJ5 that I got in transformation in getting a 350. It had a 6 banger in it. My question is what came stock for rear end in these
Solution
Just to add, any posts with a KEYWORD in orange will link to a post with an explanation. Just hover the pointer for a brief description and click for the complete post.
If it's stock - no. The axles are two piece and prone to having the hubs spin. There are several kits that replace the 2 piece with 1 piece.
Example -->> https://jeep-cj.com/community/downloads/superior-1-piece-amc20-axle-kit.24
Thread search -->> https://jeep-cj.com/community/search/549/?q=one+piece&o=relevance
-->> https://jeep-cj.com/community/threads/one-piece-20s.40425/
-->> https://jeep-cj.com/community/threads/one-peace-axle.18175/
-->> https://jeep-cj.com/community/threads/one-piece-axle-install.52054/
The axle tubes have been know to spin but a simple welding job can fix that. There are also truss kits available.
The gears are stronger than a Dana 44 .
I like the color, looks good.
What one piece axle brand did you go with?
The gear oil is good old standard 80w-90 gear oil but if your axle is equipped with a Limited slip diff. you MUST included the required additive.
The gear oil is good old standard 80w-90 gear oil but if your axle is equipped with a limited slip diff. you MUST included the required additive.
I went with the G2 AMC20 Kit. I am Prob going to paint body next winter its a little ruff around the edges
Thanks for the info
Trans 81 CJ8
