What carburator do I have?
babyboomerboy
Kansas
1967 Jeep CJ5
225 V6 T-86 D-18 D-27/D-44
looks like a rochester 1bbl, could be a carter though. pull it off and see if there is a tag with numbers on it, numbers stamped on the fuel bowl, or stamped on the base plate.
It has Rochester 2 Jet on the top of the fuel bowl, but I guess there are a lot of these and each takes a different kit. Thats why I need a number so I can get the right kit. Thanks
There should be some sort of id numbers stamped on it some where I have a carb similar to that on my boat, if I remember right it was on the base plate and it was more of a letter designation than a number.
Sent from my DROID2 using Tapatalk
Thank you for your response. I guess the only thing I can do is to just take the carburator off and really go around the thing till I find a number if there is one.
ROCHESTER 2CG IVE HAD NO LUCK REBUILING THESE TROTTle shafts wear in carb not easy 2 fix ive got old holley dominater intake edelbrock 500 runs awesome
How do I? Oil seal
