What gears should I run
4.27 gears are not available for these axles (20/30). The decision is going to be between 4.10's and 4.56's. If you want really low, the 4.88's are there.
What plans for this Jeep? How much pavement is it going to see? Highway use?
Even with 4.10's, you are winding the 258 up pretty good at 65-70mph. My 4.2 always sounded like it was going to come apart on the freeway at those speeds, but with a redline of 4,500rpm's, that's what you get with the 4.2 *shrug*
I ran 4.10's with that exact settup and it was as close to perfect for onroad/offroad as you could get.
If you're strictly offroad, by all means go 4.56 or 4.88. A better option honestly however would be to drop in the 4.10's and if you want a lower final ratio, install a 4:1 in the D300
EDIT: Is this a 6cyl or a 4cyl?
Just talking from experience as I had the exact same settup....AMC 258 i6 / 4.2l /T-5 /Dana 300 , 4.10 gears and 33'sThe T5 has an overdrive that keeps your RPMs from shooting through the roof on the freeway. 4.56 gears wouldn't be unreasonable for a T5 equipped CJ.
Just talking from experience as I had the exact same settup....4.2/T5/D300, 4.10 gears and 33's
Edit: At highway speeds, my rpm's were in the 3k's which is a lot for the 4.2 running extended periods. Couldnt imagine what the 4.2 would sound like at those speeds running 4.56 gears.
That doesn't make any sense. Something in your setup isn't what you thought it was. Are you sure you had 4.10's? Did you shift into 5th gear? Are you sure your 33's were really 33" tall? Are you sure your tach was set up for a 6 cylinder and not a 4 banger?
At 65 MPH, 33" tall tires with 4.10 gears and a T5 in overdrive should put you just a little over 2300 RPM. Maybe 2400 if your 33's are a little short. 4.56's only take you up to 2600 RPM at 65.
Even with 4.88 gears, you shouldn't be hitting 3K RPM without 31" tall tires or shorter running a T5 with overdrive.
I could see if you had a T4 without overdrive. With that combo, 4.10s and 33's puts you over 2700 RPM at 65. Higher if your 33's aren't really 33" tall.
Soooooo is the 4banger tach diffrent than the I6 tach?![]()
Soooooo is the 4banger tach diffrent than the I6 tach?This CJ originally was a 4cyl model which is equiped with 4.10's from the factory. I never swapped them out, but verified that that's what they were on several occasions (rebuilds, locker installs, upgrades, etc)
