What is correct carb for 304?
OEM1984CJ7
E. Tenn
1984 CJ7 258 w/T176
Bored .30 over what is the best motorcraft carb for a AMC 304 ? I found a MC 2150 off a wagoneer with a 360 and it has 1.21 stamped on the side. Wondering what the original was and if this would be good to run after rebuilding it?
thanks.
The 2150 is a good carb. It was normally found in 1.08 and 1.21 flavors. Your .30 over AMC 304 is still less then 360 cu in so the 1.21 should do you right. Unless your running an aftermarket intake and carb then you may need up upgrade. Most stock v-8s in the AMC 304 range run good with carbs less then 600 CFM.
