Engine 258 carb replacement
Convert it to a two barrel MC 2100
What is the best and easiest replacement carb for the 258? Thanks
Same problem with my '79 CJ7 . What intake manifold? Can you use an adapter and is it reliable?
Same problem with my '79 CJ7. What intake manifold? Can you use an adapter and is it reliable?
My manifold isn't craked. The 1 barrel carb is just failing.
$90.00
  45.0%
