What is my 258 suppose to look like? Suggestions!
RenegadeCJ7
Greenville, SC
1978 CJ7 Renegade
1999 XJ Classic
Getting what you have to run right is a start, like an air cleaner to begin with.
she runs! i do need a new pcv grommet and probably kit lol the PO had it running inside something else, it was weird plus its crumbling, to NAPA tomorrow hopefully!
Interesting, from those pics I do not see coolant lines running thru the intake manifold. I once disconnected my coolant lines thru the intake manifold and the engine ran like :dung:.
If your refering to mine it did not have them, it is the ca. AMC 258 i6 / 4.2l with the carter yf.
If your refering to mine it did not have them, it is the ca. 258 with the carter yf.
Sasquach, I was referring to all of the pics, except mine of course, having a later CJ. Since I would think that without coolant passages, it would make for a quite a warm air/fuel mixture.
Well I never got mine to run good untill I did the mopar system.
After looking back and remembered my engine leaking oil really bad. As mentioned already, pressure washing will help tremendously. I would have bet money I had a leaky valve cover. After some engine brite and pressure washing I discovered the dipstick leaking. RTV silcone has been holding now for sometime. After the local mopar dealer telling me goodluck on finding a dipstick, I told him well....
Sent from my DROID RAZR HD using Tapatalk 2
$35.00
  17.5%
