What is the 4bbl version of the 2100 carb?
JeeperChris
Old Time Jeeper
Michigan
'79 CJ5, 258 I6, T150 w/Dana20, Dana30 front and AMC20 rear. My first Jeep! I'm looking forward to doing some minor upgrades and restoration while enjoying the ride.
Been a long time since I've looked for Motorcraft carbs. What is the 4-barrel version of the 2100 2-barrel?
Anyone know about the cfm sizes too?
I'm not sure to be honest but if ur trying to run a 4 on a 6cly or small v8 like the AMC 304 then it's way too much carb and it will not run very well. Sometimes less is more
Sent from my E6810 using Tapatalk
Motorcraft 4 barrel is a 4100
Sweet glad to see you around Caveman
They did install the 4100 on the 289 so there are smaller bore versions out there, however it is a Jeep so go conservative for better low end throttle response
Thanks Caveman, that's the number I couldn't remember!
Gert, yep I've been reading up on these again. Don't know if I'll get one or not but it's worth a thought since the 2100 is such a great 2 barrel. I've been looking for one of the 475 cfm 1.08 bore carbs and I think I found one. Of the many engines it was used on besides the 289 one of them appears to be the Fairlane with a 200cid straight six. That sounds like a perfect Jeep carb to me.
Right now I'm just looking and thinking. I think it's called "pondering" :-)
Holy cow they made a 4 barrel inline 6 from the factory
I have read that they did but i have not confirmed this yet. Can't do this from the phone because the mobile sites won't show everything, i'll post the link i was reading when i get home tonight so you can see what i saw.
Here's what I was reading, it's a 4100 on ebay, just scroll down to the compatibility chart and you can see many listings of the carb working for the I6 engine.
It also may just be that they threw every engine into that list without specific regards to the carb that was used since this is the only place I can find the 4100 listed for an I6.
https://www.ebay.com/itm/1966-Ford-...AOSwLPpdrKqQ:sc:FedExHomeDelivery!48357!US!-1
I've been around. Just having a hard time posting most of the time.
