What to look for when buying a tow bar
AeroMoto
Fort Collins, CO
1973 CJ5, AMC 360, 4" Rancho lift
Exactly as the title suggests. I don't know much about them, but was hoping to find a used one for cheaper off Craigslist. Plan is to bolt the mount to the bumper. The front is a wench bumper so it's plenty strong. I just don't know what I don't know about tow bars. If that makes sense.
Got mine at Harbor freight, it works ok I guess but I sure like the trailer better. Torx is right , an art. you have to stay wired tight all the time and they do very definatly have a top speed. finding it can be exciting, as can cross winds, quick stops, big trucks. sudden lane changes.......
I would guess that a CJ is not the ideal vehicle to be towing as well, short, narrow and tall. And pay close attention to tire pressure and loading.
good luck:cool:
I got mine from 4Wheelparts looks like all the others is adjustable and came with the mounts for the bumper. Have been using it for around 10yrs with no problems. I tow it behind my 1ton pu with a big camper on it and will do highway speeds and high mountain passes no problem. The only time I can tell it's back there is stopping and starting. The rest of the time I'm checking my mirrors to see if it's still there.
I use to have a motor home that I towed a Cherokee behind. Went with a car hauler trailer because it is the only method you can back up with for any distance. I'm bad about going head first into some place I shouldn't. :eek: Rod
to be honest, the only time I used the tow bar was pulling the CJ with a Tacoma, a little light, and the reason I now drive a Tundra. I am sure that with a 1 ton and a big V8 you would hardly know it was there. :cool:
I don't think I spent more than $50 on the towbar from HF but the best buy was the magnetic mount towing tail lights. worth every bit of the $10 they cost.:cool:
Right on IO :)
