Misc. where buy motorcraft 2100?
fieldofdreams
Van, Tx
1982 Cj-7
Can anyone tell me where to purchase a motorcraft 2100 carb for my Cj? Thank you, any help is appreciated!
google comes up with aftermarket units.
junkyards, ebay, swap meets, etc etc etc.
look for one with 1.08 Venturi (sp) common on the 72 bronco with the 302.
Sent from my E6810 using Tapatalk
There was a guy on amazon in Colorado I've had luck with a few times now. They're reman units, or aftermarket most of the time. But they bolt on and run no issues. Little tuning from there.
Figure out CFM needs and match as close as you can. Also jet sizes may need some tweaking. Choke style, and some models have elevation adjustments (2150 I believe?).
Elwood Blues had some good write ups on here for 2100's / carbs.
If you go junk yard - eye the normal vac leak areas. if the throttle plate shaft has too much slop / play, find another or plan on sleeving it.
Mike's carburetor is also a goo place for rebuilds / parts I believe. https://www.carburetor-parts.com/ lots of info and knowledge there...
Cheers
