Where is your CB radio mounted?
elwood blues
Always Off-Roading Jeeper
Export, PA
1978 CJ7 4.2L Comp Cam & valve train, MC2100 carb, MSD ignition, Dana 30 front, T18 trans, Dana 20 txfr, AMC 20 rear.
I've finally gotten around to doing some rewiring in the CJ. I've ripped out the crappy tape deck radio, the single speaker in the dash. I've got a pretty nice Pioneer head unit to put in the Tuffy center console, wire up a couple of new speakers, that kind of stuff.
I just can't figure out where to put a CB. I've got a couple, a small Cobra 19 DXIII, a Cobra 18 ultra w/ weatherband, and somewhere in one of the boxes I've got a really big old Uniden, somewhere. I've looked at putting it in the factory radio hole, which the PO cut out to fit a new stereo, that he took out before I bought it, I've also looked at mounting it to the back of the Tuffy console, but I don't know that I like that idea.
If you've got a CB, would you post up a picture of where it is and how it's mounted? Just so I could get a few idea's? Thanks :chug:
I run full roll cages so mine are mounted on teh spreaders between the main hoop and the front hoop, oh I put 2 spreaders in just so I can mount them there. I mount my CB in front. My 2 meter behind that both angled down to use less room and the speakers I mount on the main hoop facing forward. If you run a dual radio system like that you need to mount the antennaes on either side of the cab so they do as little interference of each other as possible
I have an 50mm ammo can for a center console and it fits my CB, my stereo and an Amp for my speakers plus all my paperwork and anything else I need.
Elwood,
I saw on another forum where the guy mounted the CB to the underside of the lid then made a jumper where the microphone attached to the outside of the lid. If I can find it again I will send it to you:chug:
is it hard to hear the CB with that set up?
I can't hear anything on the highway, but I can hear it fine on the trails and going slow on the back roads.
I have thought of mounting a speaker closer to my head, and will some day.
In all my Jeeps I have run the CB mounted off the winshield frame or the bar off the full cage. I can hear it fine. and grab the mike easy.
