why not a spool
why not a spool
cymbash
camden ar
1980 cj-7 amc 360 4 speed 33.12.50.15 swampers
does anyone make a spool for 4.11or 4.56 gears for jeep model 20 rearend. the ones i found 3.08 is the lowest i found.
i thought you had to change the carrier when going to lower gear such as a 4.11 or a 4.56
carrier needs changing on the 3.08 threshold lower than 3.08 (numerically higher) all have the same carrier
numerically less then 3.08 all have the same carrier but a different carrier to numerically above 3.08 so depends what gears you have now but if going spool or full locker they replace the carrier anyway
    Best for votes
    on specific items
    Best for votes
    on specific items
